fairway2002
Oct 28, 2018Explorer
carringb wrote:
Yup. Diameters don't match. Either replace the other side, or switch to a 2-channel valve setup, so each side will be leveled independent. Independent control will reduce body roll as well, since air won't transfer when weight transfers in turns.
This is interesting. Explain a little more. If I have 100lbs (this is just a value for conversation) in each bag with a single valve. How does a 100lbs in each bag with two valves help role? I trouble shoot electronics so I see things different
Thanks
