wolfe10
Mar 13, 2016Explorer
Bottom line-- you need to remove the FILL plug from the rear axle and check for level and more importantly for fluid contamination. It should be the "stinky" gear lube. Clear, slightly yellow-brown, NO WHITE (sign of water intrusion).
