wolfe10
Mar 13, 2016Explorer
If the differential is letting out that amount of "liquid", you absolutely need to remove the FILL plug and check the oil.
That is a LOT cheaper than having water in it and having to replace/rebuild the differential.
The vent should only let small amounts of AIR in and out with changes in temperature.
