gshantz's avatar
gshantz
10 years ago
freightliner suspension
I have a 1998 Fleetwood Discovery (35 ft. Diesel pusher) with air ride. I just replaced all the tires and afterwards, the ride is suddenly terrible. It feels like I have 4 very low tires in the rear and it sways when making a turn or steering correction. The front steering is very tight and if I make a short turn (not quite enough for a lane change)and then hold the steering wheel steady, there is about a 2 second delay and then the rear sways in the opposite direction enough to make a large direction change - enough to actually change lanes. I went back to the tire company and they even changed the back tires around to no avail. Their only recommendation was to pay for a $200 front end alignment. What bothers me most is that no one seems to have heard of such a thing happening. The tread on the tires I replaced were not worn, just old and cracked.
Has anyone got a suggestion as to where to look for answers?
Thanks
  • Never had the front end aligned on my coach in 12 years, no issues. I think the correct air pressure in your tires once you know your correct axel weights will make the difference.
  • WILDEBILL308 wrote:
    What are your axel weights and what is the recommended tier pressure? What load range tiers are you running? Did it drive ok before?
    Bill
    I feel a little unprepared for providing the necessary info for this. Sorry. I need a few days to collect the relevant data. For tonight, all I have is the receipt which only shows the tire size -- OSP truck 245/75R 22.5 Toyo M154. They are steel belted radials, but I don't know the specs yet.
    I'll try to find a scales for actual weight and also get the GAWR. I know I'm loaded pretty heavy. The tire store told me the max pressure was around 120 lbs, but we set them all to 100 lbs. I asked if increasing the pressure would help and they didn't 'think' so.
    I thought the word "suddenly" would indicate a change from good to bad handling, but I didn't really make it very clear. Yes, I was always so pleased with way the rig handled before - like a dream actually.
    I don't know if the store kept any kind of record on the removed tires, but doubt it. Being a 1998, it was the old style of tire size and I'm sure they made an effort to match up the new tires. They said the size difference was less that a quarter inch in height and width.
    Bob Wexler wrote:
    You may need a four wheel alignment, and ride height adjustment, not just front wheels.
    If I need to follow through with the alignment, I'll definitely inquire about this.
    I sure appreciate all the support on this question so quickly. I'll get back ASAP with the other pertinent info.
    Bill
    Yep,
    That's what I was going to ask too. Do make sure that your psi in the tires corresponds to the ACTUAL weight of the coach. And yes, I was also going to ask how well the coach handled BEFORE any tire changes. While it would be time consuming and, maybe a bit of a cost involved, it might be worth it to change all the new tires BACK to the originals, IF, the company still had them.
    This of course, is just a suggestion.
    Scott
  • What are your axel weights and what is the recommended tier pressure? What load range tiers are you running? Did it drive ok before?
    Bill
