Mortdd wrote:
I have a 2013 Coachmen Encounter, that has been plagues with may problems from day 1.
The latest is I finally have a need to sterilize the fresh water tank. BUT there is no way to put in a solution of Clorox and water. It appears to me that the manufacturer used the same type of connector for the fresh water tank as for the city water connection. Thus requiring pressure to put water in the tank. And also there is no vent to let out air when filling like there has been on my other RV's.
Any thoughts???
Thanks,
Mortdd
You vents are the overflows and most have two.
As for taking on chemicals and container water there are ways to produce suction, but the easy was, as said, is to just fill your empty water hose with bleach and hook it to the spigot. Even stringing it vertical up to the roof if necessary and attaching another hose to it.
