dougrainer
May 11, 2016Nomad
1. Need to know type of motorhome and chassis
2. Need to know brand and model of refer
3. Simple answer is, IF REAL deep cycle batteries are installed and you do deplete them in transit, that should NOT destroy a TRUE deep cycle battery as they are designed to be discharged and recharged
4. Depending on the model refer, some have a Chassis ignition interlock that only lets the refer run on 12 volt when the Key is ON. The other problem with 3 way refers is IF the OEM did NOT install a HEAVY enough gauge 12 volt power wiring to the refer. Usually, the MINIMUM gauge for a run depending on how far the batteries are from the refer is 8 Gauge wire. Doug
38,771 PostsLatest Activity: Apr 21, 2026
