I used to be able to travel down the road with the refrigerator on gas, but lately the pilot goes out most of the time. Any ideas what the problem could be? Thanks.
Do you have a pilot light or an ignitor that lights the gas when needed? Either way clean out the tube coming off the gas valve. It's likely full of rust particles. Also tap on the stack going up above the flame to knock any rust loose. If you can remove the gas tube that would be good or you can used compressed air to blow it out. We had the same problem on our previous MH. After cleaning it ran perfectly.
