Bill.Satellite wrote:
Yep, there's the "let's sue everyone" response.
Really... Can you point out where I said to sue everybody?
There is a reason we have a court system. If you go through reasonable channels and cannot get resolution and are certain you are correct, you can go to court and a judge will determine who is right.
There would be nothing wrong with filing in civil if a repair facility not only didn't fix your engine right but neglectfully damaged your radiator and overlooked a more serious problem that caused complete engine failure AND refused to take any responsibility.
Now, if one were suggesting to inflate the "lawsuit" for emotional distress etc., then I could understand your comment. I'm sure if this happened to you, you would just let it go right? And there should be no repercussions for a repair shop completely botching a job and causing further damage right?
