Mkos1980's avatar
Mkos1980
Major elec problems.
Issues I am having. When breaker for converter is turned on , It blows my 15amp "kitchen" fuse HARD. All other 12V items are fine. converter seems to be working perfectly. That wire that the fuse is attach too goes out to a small box on my frame where it goes to the slideout and then to a loom that goes up into the trailer wall. I ran that wire to the slideout section to isolate which side is bad and it doesn't blow the fuse on the slideout part. I attach that 12v wire again to the one going in the loom and its fine on 12v when breaker is off but when on it blows. My fridge, range hood and furnace do not work at all. With battery on or off. Converter on or off. I don't even know where to start looking. I have 12v power going into that line with out the converter why would it blow when its on. Its still 12 volt. I jumped that wire in the box to another terminal and it blew that one as well . Any thoughts? its a 35amp older one.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
