Gundog
Jun 16, 2019Explorer II
Front AC not working?
My 34' 2005 coach has 2 zones for the AC the front does not seem to be blowing cold air. The rear AC unit zone 2 is very cold. Couple that with the dash air not blowing very cold air and the front of the coach is pretty hot you could hang meat in the bedroom in the back. I figure I probably need a new unit but was wondering if there is anything I can check?
If I do need a new unit is this a DIY job or is it something that needs to be done at an RV shop? I have DIY skills and a forklift to load unload the AC unit and a background in mechanical and electrical but I am not an RV tech.
I plan to have the dash air looked at. I also noticed the dash heat in the winter did not work well. The valves in the heater lines are turned on right now. I plan to turn them off and try the dash air again before having it worked on.
Thanks Mike
Have a happy fathers day!!
Thanks Mike
