diazr2
Feb 20, 2014Explorer
bob-lori-scout wrote:Yeah that's a good start but it's not always the main ground. I could be individual ground wires or even the ground wire that is attached to the bulb. I would do what CGmartine suggests. You need to check each and every ground wire all the way to the source. I have never done it that way but next time I have a problem I am going to. sounds like a great idea.
Thanks for the input! I did locate what I believe is the ground wire, it is screwed into the metal close to the fuse box. It looked fine however I will take another look and probably take it off, clean the area and wire good and reattach.
38,707 PostsLatest Activity: Feb 20, 2025
