SabreCanuck wrote:
Reading up and looking at Motorhomes and hearing about the Heat/Noise factor of Gas versus the quiet of the Diesel, mostlyd due to engine location. Also hearing about noise factor of the generator at night when on most Gasser's is at the back under the sleeping area where most diesels the gen is in the front under the cockpit. So basically a Diesel is generally quieter all the time.
That being said why wouldn't the manufacturers put a Gas in the rear of the Motorhome instead of the front? Or do they and I haven't come across it yet.?
A rear gas engine has been done by several manufacturers. Monaco had a rear gas unit as did Safari. Having had both front gas and rear diesels, the WIND noise is the same or maybe more with a DP if the front door does not seal properly. The engine noise does not prevent any normal conversation in my gas unit and I could care less about the generator. Mine generator is in the middle and I do not boonedock so rarely use it at all other than to run it to keep it exercised.
Monaco and a few other manufacturers have also had front engine diesel rigs and the noise level on them was not objectionable. Some people with DP's do not like the engine heat right below the bedroom on the DP's and if you look at the various photos of RV fires, many of them start at the rear of the DP at the engine compartment.
Of course it all depends on what part of the facts that you wish to distort to make your argument for a diesel instead of a gas powered coach.
Most of us that have had both know that the floor plan is still the most important factor and that we spend more time parked than on the road. Both will make it up any mountain towing another vehicle. Some DP's do have a much higher hitch capacity which is important to some buyers.
