tommy g wrote:
rgatijnet1 wrote:
If they did check everything in the front end they should have picked up any loose tie rod ends, etc, but did they look for any looseness in the steering box itself. Does your wheel feel tight or does there appear to be a little more "play" in the wheel then before.
"THAN BEFORE" is hard to relate to. It's like other people noticing how fast you change when you don't. That is another good suggestion for my mechanic though....thanks.
I know what you are saying but when a steering box gets loose, especially if it happened on a rough road, you find yourself wandering a little more when on the highway. If you sort of noticed that you had to correct your steering a little more than you remember before it may have been the steering box rather than the 6 beers. :B
