jvernon wrote:
I have monaco 36ft dp. Dealer said 115lbs in front tire. When i go over a bridge or any bump ... Wham !!!! It is loud. My rv neighbor has 38ft monaco dp. He weighed his ... 10,000 lbs on the front and closer to 18k lbs on the rear. He told me to take front to 90 lbs and it will be night and day going over bridges. Good advice ?
Weigh first and then use the tables (most manufactures are close to the same) for your tire size. I always add at least a 10-15 psi cushion as well for weight variations, changes in ambient temp. and for possibly catching a slow leak in time. This usually doesn't noticeably affect the ride and should perform better on a 1-10 scale......
CLICKITY
