Class A drivers, how. do you maximize your money spent on fuel, over the milage gained do you shop for price.? do you alter your driving? do you added gizmos? ME? I set the cruise at 65+_...
My HP to LB. ratio is 66.3 HP to 1LB weight, if loaded to max weight. I never load anywhere close to max weight, always a several thousand lbs. under limit. Therefore the HP to LB ratio is greater than 66.3 to 1. I prefer truck stops and Flying J in particular.
