gsf35099
Oct 12, 2014Explorer
dogvetia wrote:
I have the 300 ISB albeit on an older (2004 journey) freighliner. It has only one filter --with the electric and water separator all in one. I have had a freightliner mechanic look to make sure I was not missing the second filter but it is not there. I have 90,000 miles and 9 or 10 filter changes under our belt with no issues . the procedure described is what I use--ie fill the filter with fuel and then install. lots better to have it start rather than trust the electric fuel pump to fill the filter once installed.
Thanks a bunch. Pretty sure I only have the one filter as well. I've tried searching YouTube and haven't found anything.
38,776 PostsLatest Activity: May 15, 2026
