11178adm
Apr 22, 2016Explorer
Mrwizard wrote that the fuel leak is on the rounded end of the pump, this being the governor end, check the fuel lines above that for a leak as there in no fuel in the governor, only oil. all of the fuel is in the area where the 6 fuel lined come out of the top of the pump in a straight line and go to the injectors the pic. shows as #10 that is #1 inj. line the others go to @2 3 4 5 and 6 injectors. #6 in the pic is the supply line from the filter and #12 is the return line. with the engine not starting it sounds like the engine has lost it's prime from a loose or cracked line. the high pressure lines from the pump to the injectors have a lot of clamps that must be in place to keep the lines from cracking from vibration, if any are missing they need to be installed properly
hope this helps
hope this helps
38,782 PostsLatest Activity: Sep 02, 2026
