Whataday's avatar
Whataday
Fuel leaking from within the generator
I parked my RV on a slant (forward down) and the next morning noticed a major leak from below the generator. I lost about 30 gallons of gas, before I finally put it in neutral and coasted it down the driveway to a more level spot. The leak continued. It seams as though once I lost enough gas from the main tank to the generator, the leak stopped (started with a full tank and now have 1/4). I looked on the back side of the generator to see if there was a cracked hose and the hose going into the generator looks good. Now I'm faced with opening the back of the generator to see what may be going on inside. It looks pretty tricky to unbolt the metal housing that the generator sits in, to get access to the back panel of the generator itself. Any help would be appreciated.
2007 Forest River-SunSeeker 4000 Onan Generator
