rgatijnet1
May 15, 2016Explorer III
I am guessing that you may have to drop the tank and replace the broken studs with Rivnuts. Rivnuts are threaded inserts where you will use a bolt instead of the nuts on studs as before. Rivnuts are installed just like a pop rivet. I'm guessing that the studs were welded or pressed in to place.
