Jazzyjules2006's avatar
Nov 08, 2015
Fuel stops on SB I65 Louisville, Ky to Mobile, Al
New MHer here. While I've driven this route many times via auto, never in a 35' MH with a toad. Looking for recommendations on specific fuel stop sites with ease of access for gasoline MH.
  • Please do multiple post
    See thread running in Roads and Routes
    Admin
    RV.Net
  • For the best advice I can give follow this link
    http://forums.motorhomemagazine.com/index.cfm/fuseaction/register/sup/1.cfm
    Read DOT number 2
  • 35'.. Just about any good convieniance store/gas station at about any exit. Same for most any truck stop. When you get reqady to gas up, try to avoid lunch times or breakfast times. Most interstate exits have signs before the exit indication what fuels and brands are available. When you get off the exit, just take a look at the places. One with pump islands parallel to the store front are usually best for larger vehicles. OK, so you are going to take up the entire island, you are going to buy enough fuel to make up for that. After swiping your card, if the pump stops before you get filled up, don't reswipe again, just go on down the road to another stop that appreciates your business enough to let you fill up completely. If a store doesn't trust you not to do a run-off with a motor home and toad, they have enough business as it is and don't need mine. Pilot truck stops expecially irritate me. I won't stop at one unless I have to, and then just enough to get me to somewhere else.
  • You need one of these. Tells all of the fuel stops on all interstates and which are big rig friendly:
    The Next Exit: www.amazon.com/The-Next-Exit-2015-Interstate/dp/0984692134
    http://www.amazon.com/The-Next-Exit-2015-Interstate/dp/0984692134
  • Use the App called RV parky or the good Sam's map tool. They will show fuel stops.
  • Why are there duplicate posts?
