bsportExplorerApr 11, 2019fuel troubleMH runs good using cruise control then if I touch brake to stop,trouble I lose speed and seems to lose power, its like fuel filter is blocked . it happened today again then it run fine the rest of th...Show More
HadEnoughExplorerApr 12, 2019This is most likely an electronic problem, not a fuel problem. Sounds like you're going into limp home mode. Often this is due to a faulty sensor or wiring going to a sensor.What are the OBD codes it's throwing?
Related Contentany one having trouble with their lance camper roof ?fuel troubleTrouble fuelingTrouble with CaliforniaFuel Station Troubles
