MH runs good using cruise control then if I touch brake to stop,trouble I lose speed and seems to lose power, its like fuel filter is blocked . it happened today again then it run fine the rest of th...
What chassis? Depending on how old the rig is, you may or may not have a throttle cable. Same with the OBD code, they only applied to vehicles 96 and newer. You would be getting a check engine light to indicate there was a fault code.
