bsportExplorerApr 11, 2019fuel troubleMH runs good using cruise control then if I touch brake to stop,trouble I lose speed and seems to lose power, its like fuel filter is blocked . it happened today again then it run fine the rest of th...Show More
wolfe10ExplorerApr 18, 2019Is the Allison shift pad changing gears that it indicates immediately before this happens?If a single window-- is it still showing 6 when this happens or the "engine brake pre-select" gear?If two window, is the left window doing the above?If so, that would suggest that the exhaust brake may be coming on and not disengaging.
Related Contentany one having trouble with their lance camper roof ?fuel troubleTrouble fuelingTrouble with CaliforniaFuel Station Troubles
