MH runs good using cruise control then if I touch brake to stop,trouble I lose speed and seems to lose power, its like fuel filter is blocked . it happened today again then it run fine the rest of th...
Agree with others. Sounds like your Jake brake is hung in the on position from time to time. The cruise doesn't let off enough to activate it , but you do when you let off the pedal
