Just completed a dreaded oil change on the Bounder. The Fumoto valve sure makes it easier and cleaner to drain. However, there is no way (or I haven't found it) to take that filter off without makin...
I usually punch a hole is the bottom of the oil filter with a screw driver to drain the filter before I unscrew it. It makes it much easier to control where the oil goes.
