wny_pat1
Nov 12, 2013Explorer II
GlennLever wrote:wildmanbaker wrote:
Just curious, why are you not towing the jeep 4 down? It is tow able 4 down isn't it? And if you did tow it 4 down, you would not have to worry about the trailer. It would be easier and quicker to hook-up.
You DO have a GREAT looking rig!
There is a debate as to if it can be tow four down, best advice was to disconnect the rear drive shaft and unlock the front hubs. I do not feel like crawling under the Jeep each time I want to drive it.
Glenn,
Just check here, to see if it can be towed 4 down. Just plug in your info. Don't see any reason you can't tow it 4 down!
