GlennLever
Nov 12, 2013Explorer
wny_pat wrote:GlennLever wrote:wildmanbaker wrote:
Just curious, why are you not towing the jeep 4 down? It is tow able 4 down isn't it? And if you did tow it 4 down, you would not have to worry about the trailer. It would be easier and quicker to hook-up.
You DO have a GREAT looking rig!
There is a debate as to if it can be tow four down, best advice was to disconnect the rear drive shaft and unlock the front hubs. I do not feel like crawling under the Jeep each time I want to drive it.
Glenn,
Just check here, to see if it can be towed 4 down. Just plug in your info. Don't see any reason you can't tow it 4 down!
Even it it said I could tow it four down I would not do it because of the value of the CJ. It is a true survivor (80% of the paint is original, no major component has been taken apart or modified). Pulling it four down behind the MH is just asking for damage for the elements and grim.
