GlennLever
Nov 14, 2013Explorer
jeepfreak wrote:
The cj with the dana 20 transfer case can safely be towed 4 down but that looks to be around an 82 or 83 and they have the dana 300. I modified my 300 by welding teeth on the shifting collar that is always turning while the drive shaft is rotating. What happens to a stock 300 is the gear oil doesn't circulate and the rear bearing burns up and seizes.
Year 1984, Engine 258, Transmission T176, Transfer Case Dana 300, Front Axle Dana 30, Rear Axle AMC 20
This is a true survivor, I do not want to make any modification to the drive line as it would detrack from the survivor value.
