GlennLever
Jul 13, 2014Explorer
Ok...checked this morning and no leaks, the fitting on the bottom of the tank was damp, it is obvious that this has happened before as the 90 elbow below the fitting has the green crud on it. There were no drips from it at all (had paper towel below it to indicate drips and there were none).
I hand tighten that fitting just a touch more and will leave it until I return from this trip.
So...I wiped out the whole inside of the water station , looked really nice, and forgot to take a picture.
Cleaned up all the station panels and reinstalled them.
As you may have noticed I did not put back in the winterize connection, more on that in a minute.
Wiped out the compartment and put the bins back.
There was (as there always is) one casualty. The winterize connection must have had a plastic washer between the feral in the neoprene pipe and the pipe fitting. It is broken.
I went to Home Depot, but our area does not use neoprene pipe (not code) so they carry no parts for it. It is Sunday so all the RV supplies stores are close (well maybe not CW but with the current on going disagreement on the quality of work done on the last visit I'm not going there (Camping World Problem)
I'm thinking I could put an o-ring in there and it would work, but on Monday I should be able to locate the correct part from some place.
As it is the winterize connection and the ball valve inside the compartment is closed this does not present a problem a the present time, the system works without it.
Any ideas where I can get the parts?
38,778 PostsLatest Activity: Jun 10, 2026
