GlennLever
Aug 28, 2014Explorer
So...I have a race this weekend so I wanted to get a jump on putting the refrigerator back together.
Here is the burner and igniter as they were removed.
I took everything apart and soaked the pieces in alcohol, good thing I have a blown mechanically injected alcohol burning front engine dragster.
I examined the orifice carefully for obstructions. Do not try and pock something through the hole in the nozzle, look carefully at this photo there is a clear (maybe mica) washer in the end of the nozzle)
There is a very small hole in that washer.
If you look at the nozzle from the other end against a light the hole looks quite large, it is temping to try and find something that size and clean the inside of the nozzle, DON'T DO IT
So after soaking everything, I used a scotch bright pad to go over all the pieces and reassembled the burner. By that way this dumb thing is put together with metric nuts and bolts.
I cleaned the end of the igniter with some emery paper and adjusted the igniter gap to 3/16 of an inch.
I ran a vacuum cleaner over the whole inside of the case, tapped gently on the chimney until no more rust pieces fell out.
The Thermocouple still has not arrived yet, but as it is not that much work I put the burner back into the refrigerator. I also cleaned the ground to the spark coil. I fired the unit up and it started the first time.
I had been concerned that there was no drip tube to catch the condensation from the coil inside the refrigerator, turns out America Dream had a better idea than hanging it out through the cover, there is an internal drain, note the yellow tubing.
So...I will stop here and wait for the new thermocouple to arrive, install it, clean the frame, apply new silicone, and put the cover back on.
I'm cleaning up the outside frame and the more I clean the more it appears the frame was not originally sealed with silicone, but a material more like plumbers
putty. Any thoughts?
Next will the hot water heater, as it is also temperamental, some times it will not fire either and we have to use the electric heater in the hot water heater, which means running the generator and it takes a long time to heat up.
Any advice on cleaning and adjustment of the burner in the hot water heater, How do you adjust the mixture of gas and air on the burner?
