GlennLever
Sep 21, 2014Explorer
Ok...This is what this morning revealed.
The A/C indicator light comes on when the dash A/C is turned on.
The A/C compressor comes on when the A/C is turned on and goes off when the A/C is turned off.
The fan over the A/C condenser will run when connected to a separate battery.
The test light does not light when connected to the terminals running to the fan.
The wires from the fan run into the engine compartment, across the rear frame then forward to the electronics compartment.
I find no fuses or relays marked as A/C fan, I do find one relay marked HVAC relay (which I have not tested). I also find one fuse marked RAD PWR AUX which does test good.
Can you help me locate both the fan relay and fuse?
Vehicle Vin 46GED1814T1052706
Fleetwood # 720AV5202890
MFD ID # 02890
Chassis sate 7/96
Vehicle date 1997
MFD ID # 02890
Chassis sate 7/96
Vehicle date 1997
