GlennLever
Oct 17, 2014Explorer
So....
I'll leave a bunch of stuff out as I am sure you guys are sick of hearing me belly ache about poor service.
Well that is not completely true I will give another example of it. But will not relay a couple of other stories hat have developed over the last two days.
I went and picked up the Motor Home From Cummins in Buffalo. Foot note I have had good service from "engine service" but not so much from 'power generation" which is how they break down their services.
I stopped them from doing any additional work other than putting the front back on the motor home so that I could drive it home. The generator was not put back together and it was not reinstalled into the motor home.
Originally they wanted to charge $1,200 for that service. After much discussion it was dropped to $900.00, I got the Motor Home back, the generator in the back of the pickup and a box of parts not put back on the generator.
I had the Motor Home Parked at the storage facility at 2:00 PM
I got a call on my cell phone from UPS, it was the driver and he was 5 minutes away with the generator from the salvage yard.
I was not really prepared to start this project , but it was not raining and the generator was on hand so I started (the race trailer with tools is in the same location (no power tools, all hand tools)).
Open the hood.
I had forgotten that I had taken the hood off and repainted it to remove the "bow tie" design that I did not like, When I had it off I powder coated the hinges and made plates with captured nuts on them which made removing the hood really easy, so off it came.
The bumper came of next, there was a total of 11 bolts holding it on, three were finger tight and one was missing (reinstalled by the professionals at Cummins "power generation").
The body panels were next. These panels are mounted on a steel frame which bolts to the Motor Home chassis. This frame is held on by a total of four bolts which are accessed from the front (you do not even have to get under the motor home to take them off).
I would really like to get some pictures or diagrams on how the power slide works on the Eagles.
These are the A/C power lines that go to the generator. There are two hot legs (110 v red and black I'm guessing 10 gauge) one neutral (white I'm guessing 8 gauge) and one ground (green 10 gauge).
There are five terminals in the generator, not having taken this apart, I had to figure out how these wires get hooked up.
Fortunately I have the installation manual. There are several connection configurations, but the way mine gets hooked up is one hot (red or black goes to the first terminal, the other hot goers to the next terminal (if you look close you can see that those terminals have black wires inside the generator.
Now comes the interesting part. The generator is actually made with two separate 110 circuits, and each circuit has its own neutral. This allows for several different hookup configurations (air conditioners on one circuit and house power on another as an example). In my case they are hooked together. If you look closely you will see the next two terminals have white wires.
There is a jumper in the generator to connect both neutrals together.
The Motor Home Neutral is 8 gauge which will not fit into the terminal block. What was done at the factory (and this was deduced from the loose parts I found in the box of parts) is the Motor Home 8 gauge neutral wire was wire nutted to two 10 gauge wires and those wires were connected to the terminal strip.
The installation manual says that if this configuration is used the signal neutral wire must be able to carry 70 amps.
The Green ground wire gets connected to the last terminal.
Note, the terminal strip is steel and the wire is copper. Two dissimilar metals. The ends of my wires show corrosion. You might want to check your wires for corrosion and if you find it cut the ends off and strip it again to get fresh copper exposed . Corrosion on wire in connections causes heat.
This is the quick disconnect that holds the wiring to control the generator from inside the Motor Home.
Here are the two 12 volt lines to run the starter in the generator off the engine batteries in the motor home. Turns out the one marked with red is not the hot lead but the ground and the one wrapped in black tape is the hot lead (I wonder if someone was trying to throw mew a curve ball.
Then there are two fuel lines a supply and a return, nether which is marked, the one with the brass fitting is the supply.
So...now after figuring out all the hook ups (taking this apart would have helped a lot, time was spent figuring this out). It is time to put the generator in place.
It is starting to get dark (living up north this time of year is really a pain, gets dark so early.
And we still have to unload the truck, so we left at this point and went home.
Dragged the engine hoist up out of the basement, and picked the old generator up out of the truck.
Set it on the legs of the engine hoist so I can roll it around.
So...I have an interesting challenge waiting for me when I have so spare time (now that is a joke) merge the box of parts with the old generator and see if I can get it running again (remember Cummins did not reassemble it)
Speaking of Cummins I started working on this at 2:00, took delivery of the new generator, disassembled the front to the Motor Home, figured out how it is supposed to be connected, put the ne generator in place, drove home and unloaded the old generator and when done, the time was, wait for it, 4:30.
Cummins charge $900.00
If it does not rain hard tomorrow I will finish this install and post another update.
Oops, I almost forgot (old age is creeping up on me).
UPS made a delivery at the house while I was goofing off.
It is the chrome tip that Gillig gave me the part number for that I ordered off of Amazon. Gillig really does have great customer service!
It is a direct fit to the tail pipe extension that Gillig sent me earlier this week.
I now have all the parts to put the exhaust back into original condition.
Open the hood.
