robertbenita
Oct 28, 2014Explorer
If it were me and I had time, I would mark two of the screws (both front or both back or whichever has the issue) so I know exactly where they are before I messed with them, (in case all I can do is make it worse). Then I would count the turns as I screw in or out and do the same on both. Then I would try the system out to see if it made any difference. Once you know what the screws will change, then mark them all and make your adjustment to level. I would write everything down and put the instructions into my box of RV information I carry with me in case I have to deal with it again and I will remember what I did and why I did and how I did the fix. Getting it to work, especially given that yours requires an upgraded box ($$$) and additional wiring ($$$) would drive me to do this or get used to making the issue not bother me and work around it. Good luck!
