GlennLever
Oct 28, 2014Explorer
robertbenita wrote:
That seems to make sense to me. Seems like there ought to be instructions on adjusting the screws somewhere like in a new installation pamphlet or something. I hope it works!
I sent a message to Power gear.
Ok, how about if I loosen the mounting screws and insert washers between the base of the unit and the ceiling of the basement?
That way I am not touching the unit adjustment screws, just altering the angle which it is mount to the ceiling of the basement of the motor home?
I got this message back.
Hello,
I have attached a PDF tip sheet for adjusting these screws, try this and see what you get. Take the voltage measurements first before adjusting anything. Thank you.
Bill
This is the PDF that they sent, there is an adjustment that can be made. I do not know if I will get a chance to try it before I go.
