GlennLever
Nov 05, 2014Explorer
I did not post pictures of Palmetto Shores RV Resort in Summerton SC last night as we arrived after dark...so here are two.
Today has not gone as smooth as you would hope.
When we went to leave this morning the first thing to happen was the alarm on the leveling system went off. It said the jacks were down, all the lights flashed. We had not used the leveling system and when checked they were all up.
The system works as it should. If I press the jacks down button the air bags deflate and the jacks go down and make contact with the ground. Push the jacks up and the jacks come back up and the air ride reinflates.
I read the manual and it said that this will happen if the oil level is low, checked the reservoir and it read full, check the engine oil and it was down 2 quarts.
I added some oil but it made no difference.
I removed the control panel and disconnected the wiring harness form the control board.
We drove to Hudson Florida (Sun Coast Design)without incident.
Arrived and drove around in the parking lot, found a spot to park and got out to inspect it before backing in. Went to get back in and we were locked out.
The RV was siting in the middle of the drive way running and we could not get back in.
I had the door keys in my pocket. The rod that connects the outside latch to the lock mechanism had separated.
This latch had been replaced by an RV Service Center last winter.
I guess if this was going to happen this was the place. We worked for an hour and could not get in. We had to break a window to get in. Chose a window that is to be replaced.
Took the door apart and found the allen screw that held the rod was loose. Tightened it up and it now works again.
Discovered that I had added to much oil to the engine and it had puked out the vent on the engine and the engine is covered in oil.
In addition it sounds like the belt tensioner is going.
We are the smallest and oldest coach sitting here to get their windows replaced. Many are having all their windows replaced.
Not one of my better days. I will post some pictures tomorrow.
