GlennLever
Nov 18, 2014Explorer
I have to tell you I am not money ahead in that I have invested more money (before I learned my lesson)in repairs than what the coach is worth.
It is a bad experience with THREE difference service centers.
The bill for road service (which I talked them down on) was $575.00
What we finally did was install a remote start switch in the rear, taking power from the fuse panel feed, through a fuse, then trough a key switch and then to the ign terminal on the starter.
Turn the dash key to the on position, turn the remote start key and the starter runs as it should and the engine fires right up.
I'll have to trace the root of the problem when I return home.
We drove 250 miles today and are currently in Richman Hill KOA, Ga. Currently 37 degrees and it is supposed to go to 22
I am now concerned about winterization. The basement does have heat. What do you think?
