GlennLever
May 20, 2015Explorer
Took my 1997 American Dream in for it's Heavy Equipment New York State Inspection.
It passed (The inspector said with flying colors).
He put the driver's side electric window down and called to say it will not go back up.
Before I took it in I had it down so my wife could let me know in the turn signals, back up , and marker lights worked
Suggestions (no I do not want them to fix it, I have had nothing but problems with repair shop repairs)?
How do I get to the motor?
Ok, a little more information.
Just got back from picking the motor home up.
The window is down, but will move up and down about a half inch.
When moving up it comes to a mechanical stop, not a grind, but a crunch.
Pulling up on the window as it starts up does not help.
Ok guys, first project for the season.
I need to resolve this window issue. I looked at it and decided to remove the drivers seat to make it easier to get to the control console.
Four bolts hole the seat to the pedestal, I did not want to pull up the carpet so I removed those.
Last RV repair center cut the plug for the power to the electric seat, so I had to cut the wires. I will install a weather pack connector when I put the seat back.
With the seat removed I now have access to the control panel which covers the window regulator
In the engineers great wisdom they did not put plugs in, so that the wiring harness could be unplugged to remove the control panels. The wires have to be unplugged from the individual switches so that the wires can be feed through the holes in the panel so that the panel can be removed. This is 1 of 9 pictures taken from different angles so that I can be assured of plugging the correct wires back into the correct location. A camera and MANY pictures are your friends here so if you do this project take lots of pictures as you go.
Spot light control panel (has to be removed also)
Sorry for my dirty hands, I have been doing a lot of landscaping lately
Here is the back of the direction spot light control. A previous technician made a cut in the control panel so that the switch could be removed from the panel without removing the wires. A lazy man's way of doing this, but I can almost understand why he did it. I did use his trick and did not unplug the wires.
The control pod has now been removed from the side panel. Note the small hole in the side panel that the wires now have to be feed through to remove the side panel.
Another treasure of a past RV center repair. A new use for dry wall screws
The engineers strike again, in there wisdom they ran the wires for everything through another hole in the side panel. This makes removing the side panel very difficult.
A closer shot.
I was able to tilt the steering wheel all the way up, and telescope it all the way out, and the panel fit under it so that I could get to the window regulator without pulling the wires through the hole. Engineers should be required to work on the stuff the design!
Did you note the custom attempt with the bin tops to hold the wire harness out of the window mechanism? I'm sure I will be able to come up with a better solution. Already thinking of cutting an aluminum plate to run from the support of the regulator to the floor.
In straightening out the wiring harness I cam across an interesting harness. Note the harness wire tied at the bottom of the window sill
Here is a closer shot.
I clipped the wire tie and laid it on the floor.
It connects to nothing but itself!!!!!
The regulator is out, whole operation took less than an hour.
It did create a mess.
This is the regulator out on the work bench.
I tested it with a battery, and it would only move a half inch, time to go deeper.
I think we found the problem, time for a new regulator.
The motor itself looks ok, but depending on price I may replace it also because of what you have to do to get to it.
I wonder if this will help, part number on the motor
Tomorrow I go part hunting, I will update this thread with the search results.
A closer shot.
