bshpilot
Jun 24, 2015Explorer
Glenn - do you not have any panel meters that would tell you that AC Voltage is flowing into the coach (post transfer switch) ?
your generator / sticky transfer switch is a good case for adding some panel meters to confirm the flow of electricity...
the panel meters are 13 bucks (or so) each....for those w/ a 30a coach, you'd only need ONE meter.
personally i prefer to monitor the current consumption on both of my 120v/50a legs.
the meters are very each to install - since the current read out is obtained via an inductive pickup (just loop it thru the supply leg & your done).
