GlennLever
Jul 11, 2015Explorer
Well once again I found a surprise, and not a good one.
I wanted to address the corroded contacts we found in the solenoids in the power transfer switch
This is the shore power cord compartment that holds the power transfer swich.
We have already removed some shoddy wiring done by the previous owner in this compartment
The gray box in the foreground is a surge protector and high/low voltage monitor. It was loose on the wall so I thought I would remove the cover and tighten it back up.
What I found was it had been completely by passed, the input and output wires were wire tied together.
I traced the monitor wires inside the coach and found that all though the face plate was in place for the monitor all the circuitry in back of it had been removed.
This is an RV Electronics unit and my research says they are no longer in business.
I decided to completely remove it until I can find a replacement unit.
By removing it, it provided great access to the power transfer switch.
This is the inside, some people would look at this and say Oh my gosh, I look at it and can understand it and also know that it is repairable rather than having to replace it.
Someone has also been in here note the red circle (the black on the wire nut is not a burn, just black worn off the cover where it was rubbing)
I elected to leave this alone for now as I want to move on to the next project.
I bought some flexible files made for cleaning relay contacts.
This was the contacts that failed when we turned the generator on but it never engaged and we were running the A/C through the inverter on our last trip. Note the corrosion.
I was able to dress every set of points except one, and that one I used emery paper on that set.
The surge protection, high/low unit has been removed (it will be replaced with a new one, unless I can find a used one in good working order with the monitor, or maybe just the monitor.
All back together and the generator fired multiple times and each time the transfer switch worked correctly
Hooked the shore power up (using my conversion from three to four wire 220 volt adapter) and the transfer switch again works correctly (this connection should start a fire storm of comments).
