GlennLever
Sep 12, 2015Explorer
I have mentioned several times in several of my posts that I really like Weather Pack Connectors, so I thought I would show you what they are.
I did not buy an assortment, but went to a local fastener store and picked what I wanted.
But assortments are available, here is one sold by Jegs.
I am also showing four tools, but you really only need the crimper and the yellow handle barrle tool which I will explain later.
The crimp tool is available in a lot of different places, here is one.
This crimp tool has interchangeable jaws so you can do many different style crimps, here
and finally the three piece tool kit, you really only need the yellow handled barrel tool.
This is what you start with, a connector, and they come one, two, three, four, five, and six positions in on connector.
A crimp terminal, they come male and female and in different weights to handle different gauge wire, although I have used the light gauge for up to 12 gauge wire.
A seal and they come in different sizes to handle different gauge wire, you can use the small ones on large wire as they are flexible, they are just harder to get on the wire.
And finally the wire you want to connect.
You set it all together, I use my fingers to squeeze the tangs to hold the seal in place which holds the wire in the correct place. Makes easier to get the setup into the crimper.
Set the whole setup into the jaws of the crimper.
and in one operation the tool crimps the wire and the seal in place.
You remove the terminal from the crimper tool and you are now ready to insert it into the connector.
It just pushes into the connector, there are a set of reverse tangs on the terminal that locks it into the connector.
You now have a weather tight connection. You fold over the top and the connector is ready to go.
Now you say oh darn I put it in the wrong position!
The first thing you do is use the green handled tool, or a small screw driver to release the clips holding the end folded down on the connector and flip it back up.
This is when you need the yellow handled barrel tool.
This tool slides into the connector over the top of the terminal compressing the reverse tangs that have the terminal locked into the connector.
While the yellow handled tool is slid into the connector with the reverse tangs compressed you can now pull the terminal back out of the connector.
and slid it back into the connector in any position you would like.
The positions are labeled a, b, c, d, e etc. on both the male and female connectors, and are usually marked on circuit diagrams.
Just my two cents.
Just my two cents.
