GlennLever's avatar
GlennLever
Fun / Projects / with my 1997 America Dream
Borrowed a trailer and getting ready for some fun in the sun (it's cold here now 30's again tonight)
I went and bought a 8 inch drop hitch, the 6 inch had the deck at too much of an angle, and I think I'm going to turn the jeep around on the trailer (engine is the heaviest part so I will put it to the rear).
The tire minder came today so I will put that on
The house will be house sat by my son, who is going to do some rust repair on my other son's new to him pickup.
  • wildmanbaker wrote:
    Just curious, why are you not towing the jeep 4 down? It is tow able 4 down isn't it? And if you did tow it 4 down, you would not have to worry about the trailer. It would be easier and quicker to hook-up.
    You DO have a GREAT looking rig!
    There is a debate as to if it can be tow four down, best advice was to disconnect the rear drive shaft and unlock the front hubs. I do not feel like crawling under the Jeep each time I want to drive it.
    The plan is to purchase a custom trailer tall enough to put the Jeep inside.
    The Jeep is a true survivor (original paint, components, never been apart) I would like to protect it against the elements and use the new enclosed trailer for winter storage.
  • Just curious, why are you not towing the jeep 4 down? It is tow able 4 down isn't it? And if you did tow it 4 down, you would not have to worry about the trailer. It would be easier and quicker to hook-up.
  • Ozlander wrote:
    You could move the Jeep back a foot or so.
    It would overhang the back of the trailer
  • NICE LOOKING RIG I'M JEALOUS STUCK UP HERE FOR THE DURATION OF WINTER!
  • AK49er wrote:
    Careful with too much weight behind rear axle of trailer, it might start "wagging" at higher speeds.
    With the placement of the axles on the trailer I think it would be extremely hard to get to much weight behind the axles, in fact that is why I am concerned that there might be to much on the tongue of the trailer
  • Good looking rig! And those leaves are pretty up there on the trees. Good luck when they come down!
  • Careful with too much weight behind rear axle of trailer, it might start "wagging" at higher speeds.
