I have not been keeping you up to date on projects. I will start with the projects I attempted today.
Some days I think that if I did not have bad luck I would not have any luck at all, or maybe I just expect to much.
I ordered three different parts from American Coach and they all arrived while I was away at Bowling Green.
The first part was a new water heater. I had attempted to clean and repair the existing one, but it still does not function correctly, I will post that later.
The Atwood Water heater. HTR-WTR 10GAL LP/110VDSI/ATW
Outside of the box is undamaged, a fair amount of packing was missing from the box (this was the total packing in the box), and the heater was in the box upside down (top on the bottom, top side is the side that is bent).
The metal mounting frame is bent, and twisted, front view
Left side top
Right side top.
There is no hardware bag, one hinge is missing, and the hinge is there on the right side.
Hinge missing on the left side.
Metal mounting frame is scratched up (see photo of bent upper left side of metal frame and the photo below)
There was no installation instruction pamphlet (there was an instruction manual on how to use the unit).
Conclusion, at some point this box was opened and parts were scavenged and possibly dropped or shipped from Atwood damaged.
In any case it cannot be installed into the Motor Home in this condition. It needs to be returned for a new undamaged one.
Inner door window slider PANEL, SLIDER W/HOLE-P/O
This part is plastic unlike the original safety glass piece.
The protective coating was applied before the felt sliders and parts of the protective coating are underneath the felt sliders.
The coating cannot be removed where the felt is on top of it.
Felt sliders were cut uneven and not applied straight.
There are scratches in the upper corner of the replacement part, also look at the condition of the felt slider in this photo.
The temporary slider I made (and boy was I glad I had it in Bowling Green)is better than the part supplied (other than it is of acrylic and is getting scratch from sliding open and shut(which was the reason for purchasing what I believed to be a replacement piece of safety glass like the original)).
Just as a comment, $69.95 for a piece of plastic this size is a little crazy. I researched having a custom piece of safety glass cut and drilled for me and the price on that was $120.00. If you cannot get safety glass like the original part I would like to go that way.
And finally TRACK, SCREEN, SLIDE, THERMAL WDW 377162
It is the right color and right length, however, the new pieces are narrower (original is the top one).
It is not as tall as the original
And not the same shape.
So I believe this whole order needs to be returned.
I tried called American Coach, but no one is there, must be out for the 4th.
The text and pictures is essentially the e-mail that I sent them.
Every project I attempted today on the Motor Home came to a crashing end.
I still have not found the drains for the air tanks. Tomorrow I will crawl around under the Motor Home again, and also relocate and straighten out this mess and air line with the air chuck on it.
Tomorrow is another day.
