dougrainer
Jan 05, 2017Nomad
DrivingMissDaisy wrote:
Your heater has entered "lock out" mode. this happens when during the start sequence, a flame is not established in 7 seconds. The blower will run until the thermostat is cycled off. Most common cause is flame sensor, try cleaning and adjusting first, then replace if necessary, it is not an expensive part.
True for OLDER furnaces. Depending on his year and model furnace, he probably has the current control board that shuts the Fan OFF when the flame sequence fails. The models that have this have the Fan relay ON the Ignition module. Doug
38,778 PostsLatest Activity: Jun 04, 2026
