Kidoo's avatar
Kidoo
Furnace problems - 3 lights, any solution?
Hi, my Atwood 8535 IV does not want to keep going. It fires up, it blows, the burner comes on but as soon as the electrode stop clicking, the flame stops. It tries 3 times then I get a 3 shot flashing light, ignition problem?
I had my circuit board tested at an RV store and it checked OK, I connected another propane thank to it, no luck, I cleaned the electrode and checked the 1/8" measure, cleaned the burner, checked the two gaz valves and they are clicking good, the fans blows good.
I think it could be the electrode not sending a flame signal to the circuit board, but wonder if the board is good even though it checked good on the test?
Any idea?
  • newman fulltimer wrote:
    how old is your propane regulator?
    Probably same age as the MH, 12 years. The guy that checked my circuit board asked me If I had enough pressure, but how do I know, everything else is working, except for 2 or 3 times this summer I had to reset the water heater, it was shutting off.
