enblethen
Aug 14, 2015Nomad
Welcome to RV.net!
Check the thermostat for on/off switch
Next remove cover from the thermostat, locate the two wires going to the furnace, connect them together, furnace should start and produce heat shortly.
Didn't start? Open access for the furnace. Look for a circuit breaker mounted to the fan housing. Should have reset button.
Check for incoming power.
What make and model of furnace?
38,705 PostsLatest Activity: Jan 22, 2025
