Bordercollie
Nov 04, 2019Explorer
I once found a loose screw connection at the fuse panel that caused intermittent furnace action. Look also for loose or corroded ground or +12volt connections at the thermostat and at the furnace itself.
I had an old rig with an old furnace that was intermittent. I had to run the stove to clear air bubbles from propane lines. Furnaces have a lot of safety devices that need to work properly with a steady flow of propane.
Related Content
- Feb 01, 2026Community Alumni
