SuicideCharley wrote:
Hello, does anyone know where I can find a wiring diagram for my 91 Rexhall? It's a Ford Chassis but I'm not having any luck finding anything online. My key turns and starter doesn't engage. I have to turn the key to acc and jump it at the solenoid. Wiring is a mess as the previous owner added all sorts of weird things.
I replaced the actuator arm in the steering column but it's still not engaging so it has to be a wiring issue since it jumps at the just replaced solenoid in the engine compartment. There is no wire to connect to the ignition side of the solenoid so I need to track where it is supposed to be running from. OR add a push button start which would probably be easier but I want all things working as they should and not add a rigged up ignition on top of all the mess already created.
Check the Neutral switch.
