- JimExplorerWith my Bounder, I found that if I whacked the solenoids in the BCC with a rubber mallet, the screen would come back on. Eventually found which one and changed out that solenoid and it worked fine for 12 more years.
- RLS7201Explorer II
cm2785 wrote:
Thanks Dick! Is the battery center under the hood?
Yes, black metal box. Usually on the drivers side. Plastic fasteners on the bottom edge, then it slides down a little.
Richard - cm2785ExplorerThanks Dick! Is the battery center under the hood?
- RLS7201Explorer IIOn my 95 Bounder, the screen hangs under the TV and there is an inline fuse just before the connector on the back of the camera.
Also, the screen is powered from the Ignition relay in the Battery Control Center (BCC). Wiring print on the back side of the BCC cover.
Maybe a fuse in the BCC for the camera/screen also.
Richard
38,769 PostsLatest Activity: Apr 03, 2026
