hotjag1's avatar
hotjag1
Explorer II
May 27, 2022
Fuse location on engine a/c compressor
The engine a/c compressor doesn't kick on when activating the dash a/c button. There is no power to the wire that is connected to the compressor. I'm guessing that there is a blown fuse as it has worked fine until this spring. I have checked all fuse boxes and cannot locate the a/c fuse.
I called Tiffin and they said it was in the battery compartment. I found 4 inline connector fuses in that compartment, but they all looked good and they are not labeled as to what they are for.
Does anyone know where this a/c fuse might be on the DP in my signature?
  • Cincy Steve wrote:
    Apples to oranges, but the fuse for our '14 American Revolution is in an inline holder, buried under the dash, near the evaporator assembly. Not an easy find, even after being told where to look....
    There are several inline fuses under the dash. Rather than pay $165 an hour, I picked up the rv and told them I will continue to look for the a/c fuse. Thanks for the suggestion. I'll probably start checking all of them after the holiday.
  • dougrainer wrote:
    hotjag1 wrote:
    Thanks for the replies. I did have an a/c shop check freon level and they said it was good. Still hoping someone has a suggestion as to where the fuse might be that I may have overlooked.
    HOW could they possibly check the 134a level(volume) with NO COMPRESSOR RUNNING?
    IMPOSSIBLE. So, don't ever use that shop. Doug
    Without knowing exactly what the "a/c shop" did, I tend to agree with Doug.
    If they put gauges on it, they might be able to determine that there is SOME refrigerant still in the system, above atmospheric pressure, but without the compressor running, you can't really tell much.
    I believe they could've measured the continuity of the low pressure switch and tried to make a determination from that as well. But again, without the compressor turning, I don't think that's reliable.
    Now, they possibly could have jumped the low pressure switch, bypassing it, to see if the compressor came to life. (NOTE: Only do this momentarily as this could damage the compressor if allowed to run without proper oil circulating through the compressor.) If it did, THAT would indicate a likely possible low-refrigerant level. But if it didn't, that would most likely indicate the problem is elsewhere. If it did cause the compressor to work, then they probably would've offered to charge it for you.
    Do you know exactly what the "a/c shop" did in their diagnosis? You can try jumping the low-pressure switch to see if that cause the compressor to kick in.
    Good Luck,
    ~Rick
  • Apples to oranges, but the fuse for our '14 American Revolution is in an inline holder, buried under the dash, near the evaporator assembly. Not an easy find, even after being told where to look....
  • Thanks for the replies. I did have an a/c shop check freon level and they said it was good. Still hoping someone has a suggestion as to where the fuse might be that I may have overlooked.
  • Krusty wrote:
    I would check to make sure it is not low on refrigerant. Most common cause.
    This is the cause 99% of the time--- Low refrigerant Doug
  • I would check to make sure it is not low on refrigerant. Most common cause.
  • Ohm/voltage check across the fuse depending on if you have power on them. Also if you have low freon then you will not have power to the clutch. Sorry can't help you on location.
