- TNGW1500SEExplorer
mfinnerty wrote:
On my rig there is one under/behind the dash on the far left and one on the firewall. I have the 2003 Sunova and I don't have to remove the radio to get to it. Just lift up on the IP cover over the speedo and gauges.
Thanks! Found it. I thought I had to take off the plastic black cover around the dash. I didn't realize it lifted up on hinges. - tropical36Explorer II
TNGW1500SE wrote:
Where is the chassis fusebox? I've looked under the dash and hood. Looked where the batteries are under the steps. Is it behind the dash? I can't get the dash up until I get some radio removal tools.
Besides the suggestions, I've heard of them being under a removable panel in the top of the dash on some newer models.
Mine on the drivers side above the floor was a real booger until I figured another way for crawling down under there. Changed out an ignition switch while in a campground that way, also.
Still not the method if you're a large person and I am not. In this case, I'd be looking to remove the seat first. - mfinnertyExplorerOn my rig there is one under/behind the dash on the far left and one on the firewall. I have the 2003 Sunova and I don't have to remove the radio to get to it. Just lift up on the IP cover over the speedo and gauges.
- maanpaontheroadExplorerOurs is on drivers side by floor on far left side. Give it a try, won' t cast anything.
38,782 PostsLatest Activity: Sep 19, 2026
